I have had this Z for a bought 4 mos and smelled a strong order in the cabin, but did not know what it was. I recently was doing some work on the car and started looking for a fuel Leak. I started with the "Tis the season for leaks" and found that the Fuel damper assembly hoses seemed wet/ grease like and a strong smell of gas. tightened the the clamps and cleaned the hose. After this happened my rough idle / running went away. Could my rough running becaused simply by that. I was expecting to replace and injector... Thanks God I didn't.
I also I noticed that Fuel damper assembly has a burn't oil baby powder look. Should I still replace the Fuel damper assembly and hoses?
Thanks
-Paul1994
Fuel Leak Cause Rough Idle? - paul199421:10:39 04/11/10
